Blasting
SuperRat2110
Blasting
Post by SuperRat2110 »
What is the best media for blasting cases?
Firehawkmph
Re: Blasting
Post by Firehawkmph »
I use glass beads. Cleans them up very easily without damaging them.
Mike Hawkins
SuperRat2110
Re: Blasting
That's what I gathered it thought I would ask. Thanks for chiming in.
Larry S
Re: Blasting
Post by Larry S »
I assume you are dry blasting. Use 170-325 mesh glass beads. Do some testing first. Start with low PSI and work your way up until you get the results you want. Too much PSI will texture the surface. You don't want that.
If you are vapor blasting, forget everything I said about PSI. I vapor blast glass beads at 70 PSI.
Larry S
