Control shaft O ring
kc57
Post by kc57 »
I am working on a bike I recently picked up. When I went to lock it in gear , the control shaft pulled free. And I found most of the pieces behind the primary gear :shock: So a shaft rebuild is in order. My question is Where does the O ring go ? Does it fit in the end of the counter shaft ? Thanks K.C.
Re: Control shaft O ring
Yes, it fits just inside the countershaft from the left side (sprocket side). Use a pick to remove the old one and grease the new one before installation.
kc57
Post by kc57 »
Thank you Dale. I could not see it yesterday. But today there it was.
KC57 parts will be there Friday, Hodakapartsidaho You will have lots of little clips, springs and etc to play with. don,t loose or misplace these. put them in a safe place. Bruce
