Gday guys,
just about to fit the HT2 pipe I've had sitting here for ages on my Super Combat, has anyone got any jetting specs? Just being a bit lazy n trying to save some time at the track on sat.
Jetting info- Super combat with HT2 pipe
Reco MX- The Dirt Bike Specialists
Re: Jetting info- Super combat with HT2 pipe
What carb are you using, the original 32mm or a larger one? As far as I have heard, if you are using the stock carb, go up 2-3 sizes on the main jet and work your way back down, and move the needle one position richer.
Ok ta mate, left stock pipe on last weekend with the new 32mm, but had an ignition failure on sat so gotta sort that 1st. Was honking with the new carb though
