Jetting info- Super combat with HT2 pipe
Hilly
Post by Hilly »
Gday guys,
just about to fit the HT2 pipe I've had sitting here for ages on my Super Combat, has anyone got any jetting specs? Just being a bit lazy n trying to save some time at the track on sat.
Reco MX- The Dirt Bike Specialists
Re: Jetting info- Super combat with HT2 pipe
What carb are you using, the original 32mm or a larger one? As far as I have heard, if you are using the stock carb, go up 2-3 sizes on the main jet and work your way back down, and move the needle one position richer.
Hilly
Post by Hilly »
Ok ta mate, left stock pipe on last weekend with the new 32mm, but had an ignition failure on sat so gotta sort that 1st. Was honking with the new carb though
