Ace 100 cylinder head
megawat
Post by megawat »
Have a 1970 Ace 100 with cylinder head with two plug holes. Plug is in center hole and decompressor is in second hole canted toward rear. Is this standard or an option.
Thanks, Don
RichardMott
Re: Ace 100 cylinder head
Post by RichardMott »
If there is a second spark plug hole, it might be a Webco head.
RichardMott
Here is the Webco on my Ace 100B+. Does his look like yours?
Webco head
Webco head
MTRob
Post by MTRob »
Hi
It was an option you cold buy from different dealers back in the day (Head). The other hole is for a decompressor, we used them alot on cross country racing going down hills to slow down faster using both brakes. Find one on ebay a decompressor I liked how they worked, to slow down also to blow out water if we got stuck in a water hole during a race.
MTRob
megawat
Post by megawat »
Thanks for the help, guess I can assume the head is aftermarket but not Webco, has no lower fins. Decompressor is installed and works great.
Gary G
Post by Gary G »
Could be a super rat head.
junker2k
Post by junker2k »
It is a Compression release and we also put them in the stock heads before webco was around.
JK
bchappy
Post by bchappy »
We also used the extra hole for a Compression Release on Flat Tracks where you could not have brakes. I also used them on Cross Country for an extra spark plug. If the plug fouled I just switched the plug wire to the other plug. Bailed me out a few times.
dirtsquirt74
Post by dirtsquirt74 »
This is a question. Built a custom trials bike and the head was bored for a compression release. How do you tell the difference between a webco head and a hodaka head that was bored ( after the fact ) for a compression release?
Richard S
RichardMott
Richard S,
The Webco head is a bit larger than the stock Ace/Rat head. You can see by the photo, the head is larger than the cylinder top. A Webco head is about 1 inch in diameter larger. You need to use a B8ES longer threaded spark plug rather than the standard B8HS.
Users browsing this forum: No registered users and 23 guests
