Alsport Steen Hodaka
I ran across an Alsport Steen Hodaka. I was wandering if it was a 1972 or what. I've only been able google search one other bike identical to it. It was a 1972. White tank and fenders with Ace E motor. I have a motor # and frame #
Motor--E 21017
Frame--Z177430...... I not 100% sure on the first character. Pretty sure it is a Z
Motor--E 21017
Re: Alsport Steen Hodaka
Hello, I to purchased 1/2 a Steen this summer, I mean, mine is the same as yours, but mine is missing the rear wheel assy, I would like to know if you can send to me a picture of the rear wheel, from the swing arm back, showing one picture for each side. I also would like to know what the size of the rear tire and wheel is. With those pictures I think I can fit an ACE 90 rear wheel assy. Your help will be greatly appricated. Bruce Young,
Hodakaparts.com IDAHO
As I recall, woking on the Steen raffle bike in 2010 (I think it was), the Steen has 16" wheels stock. Ace 90 would be a 17". Still might be able to make it work, but it would be more than a bolt on swap.
Gregg
Gregg
I might be bringing one like yours Johnny to Hodaka Days to sell. If it have the room that is. It looks like it could be your bikes twin
Yes it has 16 inch wheels. Steel I'm pretty sure.
Bruce what is your frame number?
Hello, can,t find one, where should it be. looks like a old decal was on the front frame triple tree stem
tube. but only speeks left. The eng number is E--15925 bruce
On the steering stem slightly to the left . it's vertical. Mine is
Z
1
7
7
4
3
0
Z
1
7
7
4
3
0
Hello, I cannot find the frame number anywhere up front. The stem post is clean. I will keep an better eye out when I start the rebuild.
Sorry. thanks all I am looking for Steen parts, any suggestions. Bruce
I picked one up recently myself, fairly complete sans fenders, got it running but need a left inner case as the screw post is broken off.
-Forrest
-Forrest
http://www.goomer.com/honda/
My frame is stamped on the left side of the bike, on the top edge of the swing arm mount tab. It is hard to see in this picture, because of the powder coating. Click on the picture and you can see the numbers better.
