Engine build question.
Larry S
Post by Larry S »
Will a iron barrel Wombat top end bolt to a Ace 100B bottom end?
Larry S
Re: Engine build question.
I believe the answer is no, because the bolt pattern for the Wombat is wider apart than for the Ace.
There was a 125 upgrade made for the Ace, by Webco, I believe, but those have become very hard to find these days. ; D Victor
Victor is right. Different stud pattern plus 8mm studs on 125 vs 6mm on Ace engines. Different cylinder spigot diameters too.
Larry S
Post by Larry S »
Thanx Victor and Captain Eddie.I don't know if you saved me some money,or cost me some money.Now I need to find a iron barrel Wombat engine.
Larry S
Check with Bruce Young at hodakaoarts.com. You can also find him on “the Hodaka Club” On Facebook! ; D Victor
Is your goal to just build a 125? Or is your goal to build a motor which will fit in an Ace frame?
There are more options of which you may not be aware. How about disclosing to us a little more about what you are thinking? :ugeek: Victor
I have an iron barrel wombat motor. May need a new cylinder, or may be boreable, need to check with my boring guy. Rest of the motor is in decent shape.
Larry S
Post by Larry S »
My daily rider is a Ace 100B.I' m a little fart 125 lb. I want to be able to cruse at 55. I can do that now,but the engine is working hard. I am going to build a bad ass engine that looks stock. I want to be able to cruse at 55-60 without overworking the engine.I think I can do this on my own,but if it is over my head Ron Leddle can build it for me.
Larry S
Larry S
Post by Larry S »
If the engine is on the first or second overbore i'm interested.
Larry S
rlkarren
Post by rlkarren »
Dropping a 125cc engine into an Ace frame is loads of fun. This bike easily hits 60 Mph cruising speed. If only I had another Circle F... :|
