Thanks HJ,
Here's a quick reply (well it took some time and I appreciate your very detailed reply)
1. When you say you installed new clutch parts.....
I got the Clutch rebuild kit Item# 934000kit for the Mdl 92, 93, 94, and 96
It has 3 black (thinner than stock) steel clutch plates and 4 fiber friction discs (with the holes in it).
They were assembled in the same order as the old discs which was just like the drawing in the manual, For the ACE 100B clutch assembly.
(I feel there is a gray area here with the later model 100A aces, which I assume is what I have, example-Wiring diagram is same as Ace 90)
I took special care to make sure the clutch plates made it into the groves of the clutch cage while tightening the 7 screws.
Honestly I don’t understand how those plates are supposed to move when you eliminate all possible motion when tightening the cage cover down. Is there still a tad bit of spring play left?
2. There was discussion on how to blueprint your clutch.......
I don’t have access to the blueprinting article, So perhaps I need to join the Hodaka Club to gain access.
3. Are the clutch assembly screws in your clutch stock items.......
They are the stock screws with the drilled holes in the end. They are tight and wired
4. While the clutch was apart, did you measure the height of the clutch cage........
Did not measure the height of the clutch cage. What height are we looking for?
I assumed it was correct since I did not uncover any warnings from the manual. That said, seems like the manual sort of doesn’t address the model that is in between an Ace 90 and a model 100B
5. When installing the assembled clutch, did you put back the spacers you had......
I did not have a set of clutch disc spacers handy. I put back the one spacer that was on the clutch disc upon disassembly. if I had a set of spacers, I would have been able to dial that in better so, this for sure will be needed.
Q: Would the lack of spacing account for a growl throughout the entire range of clutch pull? Sounds like the shaft is getting forced into a wonky set of bearings.
6. Does the clutch rotor have smooth teeth or are the edges dinged and sharp....
On page 2 of this thread I posted images of the gears,
download/file.php?id=5347&mode=view
They seemed pretty good. Looking at the picture now there appears to be a questionable wear mark on one of the teeth but i think that is a reflection. I replaced the pinion bushing with a new one. I reused the thrust washer and btw, there was no way to tell which side of the washer was the “round edge” side. Both edges looked right angled. (sharp)
7. Is the clutch actuating arm free to move when the clutch cover is off the bike...
Arm moved freely. As well it doesn't seem to leak.
The crunch almost sounds like it is coming from the gear shifter side. with even the slightest clutch pull (like 1/4”), you hear the Knogga Knogga Knogga….). This is why I’m wondering about a crank shaft issue if the pressure of the applied clutch is putting pressure on something.
....Post photos of that cage including a view of the gear teeth inside the cage.....
previous photos are here (simply back up a few pages)
I will have to disassemble again to get complete pictures.
....verify that the clutch springs are fully seated ...
I was carful to seat the springs. This has the single 7 spring set up. Would be curious to know your approach to lining up the fiber discs, metal discs, cage and shaft teeth to keep it al together so you can tighten it down whilst keeping metal disks from getting pinched and not getting slight movement off the shaft splines. i had to do this very carefully several times. Was a PITA. The manual definition is confusing!
Thanks guys!
Dave
