interesting engine
kc57
interesting engine
Post by kc57 »
Hi I came across this engine on a mini bike site. Owner says it has 102cc stamped into the jug. What is it ?
RichardMott
Re: interesting engine
Post by RichardMott »
Looks like a Fuji. Parts are not interchangeable with the Hodaka even though they look similar.
kc57
Post by kc57 »
I don't think it's a Fuji. The oil fill on the Fuji's I have seen , are up on the top of the cover. Like a Ace 90. And the cases are different on Fuji's . But I have been wrong before. :D
Did you look at the cylinder to verify the cc's on it? And is ther a engine serial number?
Fuji also have a pattern on the sidecovers, and the left side cover looks pretty deep where as the Fuji is really close to the Hodie motor.
kc57
Post by kc57 »
Im going to email him tomorrow. I will try to get a little more info.
dirtsquirt80
Post by dirtsquirt80 »
it looks like there is some sort of sticker on the cutch cover on the top maybe its says something helpful on it. there was a company that was making knock off hodaka motors hodaka got it shut down fairly quick maybe one of those
kc57
Post by kc57 »
Emailed the owner. It's out for a rebuild. So he is unable to check at the moment. But he calls it the Hodaka clone. So most likely is a knockoff. He will check for numbers or Id marks when he gets it back. He has a friend with the same engine, they came in a Terra-Floater mini bike
MTRob
Post by MTRob »
Could it be a Yumgici & Hodaka engine.Looks like the engine in my 63 90 ace. Which my father inlaw bought new in 63 from a Great Falls MT Hodaka dealer.
Can send pictures if needed.
MTRob
Rob you must be meaning 64 hodaka ? Clarence
Lugnut68F
Post by Lugnut68F »
I think it is possibly a Phoenix engine. I have some Phoenix manuals and they have a 480 which is 4 speed 80cc engine and 500 which is 5 speed 100cc engine. The literature I have is Pabatco literature and says they were made for minibike use.
I think this is the engine I have freshening it up for him. I had one I did in a Terra Floater I had and now this one. It took mostly Hodaka parts (bearings, rings, gaskets). The shift parts were all really good so didn't have to be replaced but looked like standard Hodaka. Cylinder gaskets and rings were standard hodaka early Ace. Points and ignition were all standard Hodaka. Biggest difference was the 3 piece Left side cover/shift assembly. I still have it at my shop planning on sending it back to him in April.
