94 wombat help needed
Hello, is there anybody that can help me out with my 1972 wombat 125 it doesnt get any spark at all and i bought new points and a condensor and a hole new stator and it still wont get spark im setting the points to .021 is that correct points gap? and i also have a brand new plug and ignition coil to.
Re: 94 wombat help needed
Nope. You are wayeee off on ignition timing. When the points are set with a gap of .012" - .014", the timing will be correct. (.021" just won't work)
Jacob, If you are still having the issue of no spark and need some trouble shooting tips, I would recommend the detailed article on ignitions contained in Hodaka Club's "The Resonator Revisited", Volume 2 Number 2 dated October 2011. You can get this document and all of the past and future releases by simply joining the club. Here is a link to the club site: http://www.hodakaclub.org/
The Resonator is well worth the price of joining the club.
Jacob, what section of the country are you in? Might be someone available local to you that could stop by and help out.
Also you might try disconecting the keyed switch and the kill switch if there is one hooked up just to test for spark. One of these may be your kulprit.
