Kev
https://youtu.be/Yg7ZQPA2ZgA
It's a Circle F pipeoldmxracer wrote:Bike sounds great. What are you using for a pipe?
Its a 97 cylinder and bottom end in wombat cases with PVL CDI. 34mm Mikuni with UFO and a vane each end. Its pretty stock as far as parts go. I wanted to start from that point so I could see what the case reed mod did alone. Of course there is some porting involved but the port timing is stock. It was pretty highly geared at 15 x 64, I plan to go bigger on the rear to perk it up a bit. The ratios even on the 97 gears fitted are quite wide being only a 5 speed. I have a 30mm Mikuni to try later as well ,to improve the bottom end a bit.Arizona Shorty wrote:1. I would like to see this engineering concept adapted to a 175 Hodaka with primary kick start.
2. You show a lot of initiative to have even dared to do this because failure would not be reversible and engine cases are getting harder to find.
3. If you get the clutch thing sorted, load some photos.
4. If you get more video footage, post it. It would be fun to see you head to head with a stock or modern day modified bike of the same vintage, to get a comparison.
5. Are you running a 97 cylinder? I didn't hear a lot of bogging on the upshifts, and have you modified the carb in any way?
6. Where in Australia are you? I have been there four times now, three on account of the ARB/Warn Outback Challenge in Broken Hill NSW, and have seen a bit of your world. Just curious.
