250 ED project
Posted: Fri Nov 27, 2020 7:42 pm
by Cruisermar
Looking for any tips on replacing the wheel bearings on a 250 ED. I don’t have a shop manual and I’m not sure they even made one. At least not that I’ve run across. The front doesn’t have a snap ring holding the bearings in place. I’ve hammered on them and heated them, then hammered some more. Wondering if I’m missing something simple before I start hitting harder.
Any other tips on tearing into an engine would be appreciated. I fear I’m going to have to have replace the oil seals. Looks like a crop duster when I fire the thing up. Brand new carb jetted and tuned and fresh has. So I know it’s not that.
Much thanks.
Re: 250 ED project
Posted: Fri Nov 27, 2020 8:07 pm
Are you a member of the Hodaka Club? If so, you can access back issues of the Resonator Revisited, the club newsletter. There is a tech article about removing wheel bearings in there somewhere.
NOTE; You mentioned heating the bearings - if that was a literal report of what you've done, a slight change of procedures will help. Heat the hub but not the bearings. I like the "spit sizzle" method of identifying how hot things are getting. Of course you could just flick some water drops rather than spitting to confirm "sizzle" temp. Coming up to spit-sizzle temp on the hub will provide enough expansion to truly be helpful in releasing the bearings, but not so hot as to cause damage to the aluminum of the hub.
The tech article goes into some detail about the proper grind on your long drift punch to get a good grip on the inner bearing race for a good whack to drive the bearing out on the far side of the hub.
Re: 250 ED project
Posted: Sat Nov 28, 2020 5:45 am
I have a bearing removal tool for really tight bearings. It’s made by Pit Posse and I got mine from MetricThunder.com. :ugeek:Victor
Re: 250 ED project
Posted: Sat Nov 28, 2020 7:32 am
by Cruisermar
Thanks Ed, I’ve been meaning to join the club and just kept forgetting. All joined up now. Now to start reviewing the back issues. I’ll also look into those bearing drivers. Might be a good addition to the tool box.
Marlin
Re: 250 ED project
Posted: Mon Nov 30, 2020 8:42 am
by dirty_rat
Just as a note, the bearings have to be removed from the opposite side of the hub, the left hand bearing is knocked out from the right hand side. Use a long drift and insert through the axle hole and catch the inner edge of the bearing on the opposite side. Tap on the drift and work your way around the circumference until it comes out (make sure to heat the hub as noted above).
Re: 250 ED project
Posted: Fri Dec 04, 2020 4:15 pm
by skydoc2
Glad to hear about your 250 project. Was wondering if anyone had a whole bike or a project 250 for sale. Just finishing a super combat project and thinking about the future.
Re: 250 ED project
Posted: Mon Dec 07, 2020 4:44 pm
by Bobv07662
Great to hear of new interest in the big bore bike!
