question? i have serach the forum with no luck, and i have seareched for pictures with no luck, how did the coil mount on the early super rat frames, as where did the coil mount #23 bolt too, since the early SR did not have a frame tab ?
if anyone has a picture that would be great
thanks
super rat coil mount
Re: super rat coil mount
D-23 in stock.
Oops, I re read your question and I got it wrong. For my Rat I used two conduit clamp wrapped around the lower frame tube. . Worked well and Is hidden under the tank.
From a friend’s Super Rat
Sorry the pics came in upside down. They weren’t that way when I selected them.
When you open them up to take a closer peek, they correct themselves.
