93A rat
budpat105
93A rat
Post by budpat105 »
What you suggest for a carb upgrade on a 93A? Not wanting to go reed valve, not a full out racer, just want good running bike without the oring issue and whatever else is wrong with my carb. Maybe the 24mm carb saving is my best choice?
Re: 93A rat
You have one of the best carbs, all carbs with O-Rings and other wear type parts will wear. Get the new parts and give the carb a complete cleaning. Here’s a video I made on that carb.
https://youtu.be/1Bfmm63cJt8
notsosuperrat
Re: 93A rat
Post by notsosuperrat »
hello,whats oring? ty.
Re: 93A rat
O-rings are specialized rubber "washers" used to provide a seal between two mating surfaces.
Re: 93A rat
In this particular carburetor the O-ring mentioned provides a seal for the externally removable main jet that resides in the float bowl. If the O-ring is damaged or leaking it creates an unmetered rich condition.
Re: 93A rat
I’m not sure but I think You can take that out and replace it with a main jet. You will no longer have the quick change ability,
Tether
Re: 93A rat
Post by Tether »
notsosuperrat
Re: 93A rat
ty
