wood block
Posted: Mon Apr 09, 2018 2:40 am
by givergas
ive been looking in here for the wood block that the engine can sit on and hold steady, on its side, while you put it back together. i have some blocks of ceder that will work great for it but i need a little guidance. i just cant find the post or a picture. any help to find it would be appreciated..... albert
Re: wood block
Posted: Mon Apr 09, 2018 3:47 am
by tahoethumper
Just screw 2”x4” together and make a box/frame in any size you desire- obviously something the size that’ll hold a Hodaka motor. We use 2”x6” at Ducati, as the motors are bigger and lay deeper, depending on what position you put them in.
Re: wood block
Posted: Mon Apr 09, 2018 4:17 am
by thrownchain
I took a piece of plywood, 3/4", laid an empty case half on it, marked where the shafts would be and drilled holes thru the plywood with a hole saw. The screwed 2"x2" feet on both ends. Works for assembly on either side.
Re: wood block
Posted: Mon Apr 09, 2018 5:19 am
by givergas
yea thats what in looking for, a little help to wrap my mind around it......albert
Re: wood block
Posted: Mon Apr 09, 2018 10:09 am
On the Wombat shop manual, there is a template for making the exact engine assembly frame you want.
Re: wood block
Posted: Tue Apr 10, 2018 2:54 am
by socalhodaka
Look in the back issue of the Resonator, can’t remember what one. I posted how to do it.
Re: wood block
Posted: Tue Apr 10, 2018 2:55 am
by socalhodaka
It’s issue 2 volume 7
Re: wood block
Posted: Tue Apr 10, 2018 2:58 am
by socalhodaka
Volume 17
Re: wood block
Posted: Tue Apr 10, 2018 3:00 am
by socalhodaka
Re: wood block
Posted: Tue Apr 10, 2018 3:02 am
by socalhodaka
Oh I did not show the photo with the measurements, you need to join the club. Now that’s worth 24 bucks.
Re: wood block
Posted: Tue Apr 10, 2018 4:28 am
by thrownchain
Here's mine, 11" x 14", 3/4 ply. Once you assemble the core motor, you can flip it over and use the correct holes to lay it flat to assemble the clutch side. Works handy.
Re: wood block
Posted: Tue Apr 10, 2018 6:33 am
by givergas
I am a member. Cheap fun for the money and thanks I looked and looked just could not find it......Albert
Re: wood block
Posted: Tue Apr 10, 2018 7:22 am
givergas wrote:I am a member. Cheap fun for the money and thanks I looked and looked just could not find it......Albert
Once you are signed into the Club website, mouse over the 3 dashes on the right side of the menu bar. Then select Club Newsletter - Back Issues.
Re: wood block
Posted: Wed Apr 11, 2018 1:49 am
by givergas
thanks just what i was looking for. much appreciated...albert
Re: wood block
Posted: Wed Apr 11, 2018 9:43 am
I learned from an old sheet rock installer to put lipstick on parts to mark where to cut. You never need to measure & it’s always in the right place! :ugeek:
Re: wood block
Posted: Wed Apr 11, 2018 12:38 pm
by givergas
boy theres a joke in that statement. albert
Re: wood block
Posted: Thu Apr 12, 2018 5:04 am
Well, some folks see it as silly or funny, but when you’ve got to cut out a square hole on sheet rock for an outlet box, it works like a charm! :ugeek: Victor
Re: wood block
Posted: Thu Apr 12, 2018 6:29 am
by givergas
Yea your right. Sometimes my sence of humor gets the best of me
Re: wood block
Posted: Thu Apr 12, 2018 7:25 am
Sounds like a revlon add watching a sheet rocker putting on lipstick , I don't see the charm. Come on victor just a little humor. Victor are Hodaka Days in your path? -------Clarence
Re: wood block
Posted: Thu Apr 12, 2018 11:02 am
Probably not. June is always a busy time for me. :ugeek: Victor
