New Member Wombat Project
Posted: Mon Jan 01, 2018 12:08 pm
by Stronger511
Hello all,
I recently scored my first Hodaka! I have been able to learn so much looking at the forum and using the Strickly Hodaka website. I just wanted to post what I have and get some opinions. Looking at the frame number, I believe it is a 1973 Combat Wombat. I bought the bike with a motor in it, and a motor that is more complete. The motor in the bike is not the correct engine to my knowledge, and the other motor I have I believe is a Wombat engine. I do have a few questions about the bike. I don’t think I have the correct tank, I believe the Wombat and Combat Wombat has a chrome gastank. Also, the Wombat engine has black covers on the side of the engine and I have not seen a Wombat engine with these color covers. Lastly, there is a broken piece on the bottom of the cylinder and I am wondering if this can be repaired? I would appreciate any feedback and advice. Thank you for your time!
- Mitchell
Re: New Member Wombat Project
Posted: Mon Jan 01, 2018 1:15 pm
by BrianZ
Welcome to the Hodaka community! Your bike looks like a model 94 125 Wombat. What is the frame number? The Combat Wombat will start with a D. Judging by the stator and longish cylinder studs I would say the engine in the frame is a cast iron cylinder 100, either Ace or Dirt Squirt.
The spare engines you have are a model 96 Dirt Squirt and a model 94 Wombat. The broken cylinder could possibly be repaired, but in my opinion you are far better off looking for a good used one.
As you suspect. the black engine is not stock. Someone has been painted them at some point. The same goes with the gas tank. You should find chrome under the paint.
Posted: Mon Jan 01, 2018 1:16 pm
Welcome aboard!! You have a cool project ahead. You have a tangible example of one of the cool and unique features of the Hodaka concept - parts interchangeability. The P motor originated on one of the Ace series bikes including the chrome tank Dirt Squirts. The H motor came off a M94 or 94a Wombat. The damage extending onto the gasket sealing area is concerning for salvageability of your 123cc cylinder but there are some true wizards that have a steady presence on this site that can just about fix anything who may have another opinion. The tank looks to be from a late model Dirt Squirt and looks to be in excellent condition. It may be a M95 chrome tank that has been painted. The engine cases were probably just painted black. You didn't cite the frame number but I suspect it to be a M94/94a Wombat seeing as how you have a Wombat air box and motor. You can tell right now by looking at the steering head plate. It it says its street legal, it is a Wombat. If it says off road competition only, it is a Combat Wombat frame. There is a frame and engine identifying index on the Strictly Hodaka website for sure and maybe on the sites of HPI and Hodaka Parts as well. Depending on what the base gasket area of your Wombat motor look like, it may be fine for a rebuild. Your best move at this time is to undertake a complete disassembly of the bike down to the nut and bold level followed by a thorough cleaning, inventorying, identifying and frame inspection. Take careful notes, preferably with accompanying photos to assist with the rebuild. Get yourself an official Hodaka Wombat Workshop manual - its an absolute necessity. You'll have superb support every step of the way with the folks who contribute to this forum - I sure have! Also, there is an excellent network of parts houses that support our efforts to keep these insanely cool bikes alive. Try finding all that support for your Jawa, CZ, Monark, Rokon, etc. etc. etc. Most importantly, HAVE FUN!. Remember, its a "BOOGIE MACHINE"!
Posted: Mon Jan 01, 2018 2:07 pm
by BrianZ
A couple more observations:
The front forks are non-stock and they don't appear to be late model Hodaka forks either. It would be interesting to know what they are from and what size the tubes are.
The rubber foot pegs are non-stock and are from an Ace or Super Rat. You Wombat should have steel cleated pegs.
The rear brake backing plate is off a later Hodaka, possibly a Road Toad. It has the nice feature of inspection plugs that allow you to check the brake linings.
Posted: Tue Jan 02, 2018 12:26 pm
Looks like the frame is a 1973 Combat Wombat! It’s a D15XXX frame number! I could see the frame number in the VIN tag from the picture showing the left side of the bike! Congrats on the find!!!
Check your motors for a case serial number starting with a “J.” That would be the correct motor for it.
Here’s a photo of a restored one!
Posted: Tue Jan 02, 2018 1:00 pm
Mitchell,
I don't believe your cylinder is repairable. The broken off part is called the "spigot". It serves double duty. It "centers" the cylinder on the cases AND the skirt of the piston travels all the way down to a point even with the bottom of the spigot so it is an important part of the cylinder wall. I don't believe there is any reasonable way to weld a replacement piece of matching cast iron in place to return the cylinder to service. In addition, it looks like there is a crack in the cylinder wall at the base of the transfer passage. So, I'd have to say you have an interesting paper weight.
- Broken cylinder spigot
The photo also shows where to look to find cylinder displacement information on Hodaka cylinders. It seems pretty sure you will find a designation of 98cc on this cylinder.
Posted: Tue Jan 02, 2018 1:24 pm
by BrianZ
Good eye Victor, that does look like a "D" in the frame number. It doesn't look like there is too much of the Combat Wombat left though. The rims look like chrome plated Wombat items and the front brake backing plate has holes for the brake light switch.
Too bad the bike is not closer to Ontario. I have a spare CW motor, a set of early flanged wheels, an exhaust pipe and part of the airbox. Almost enough parts to complete the bike.
Posted: Tue Jan 02, 2018 3:52 pm
Ed. If you check the other photo of the broken spigot, you’ll see the cylinder is marked 123cc. Too bad too!!!
Posted: Tue Jan 02, 2018 4:00 pm
Mitchell - I hope you are not getting discouraged, cuz you have a good start on a great riding machine! Now, if you were hoping for a restoration to show room new and full Combat Wombat trim . . . um, being discouraged would be in order.
So here is some information which may cheer you up. The Combat Wombat frame is EXACTLY the same as the Model 94 Wombat frame AND the Model 96 Dirt Squirt frame (except for some misc. bracketry). The model 96 100cc Dirt Squirt (like the one in my garage) may well be the funnest fun bike I own! Note that lots of guys started out with factory stock Hodies and ended up with machines like yours with bits and pieces from several other Hodie models.
On looking at the photos more closely, the biggest problem I see is the forks. I'm not sure the two legs are the same. The leg I can see has an alloy slider . . . but isn't from a Hodie. The other slider doesn't appear to match . . . so I'm not sure what you have there.
You'll need to do some thinkin' to decide whether you want to re-build one of the engine "cores" you have (100cc iron cylinder) - or start searching for a Wombat/Combat Wombat "core" to re-build and install.
Have fun . . . and don't forget - there are lots of guys on this Forum willing to help in any way they can . . . and who are interested in up-dates as the project progresses.
Posted: Tue Jan 02, 2018 4:08 pm
Oh! I didn't notice that! And it is pretty hard to miss the 123!
So Mitchell, the engine "bottom end" with the 6mm dia. cylinder studs (I think) appears to be a 100cc "core". If the studs are 6mm, then the engine is 100cc and can be re-built with a 100cc iron cylinder. If the complete engine with the black clutch cover is a 125cc engine . . . then you are well started with either engine size!
Posted: Tue Jan 02, 2018 4:11 pm
DOH! . . . and the "H" on the engine serial number makes it a 125.
Posted: Tue Jan 02, 2018 5:13 pm
Let me know if you can’t find another Model 95 Cylinder for your bike. Also, Bruce Young, (Hodakaparts.com) May also be someone to check with. He may have a workable cylinder for you!
Posted: Wed Jan 03, 2018 10:29 am
by Stronger511
Thank you so much everyone for the valuable information!! I have attached a picture of the frame number and I do believe it is a Combat Wombat Frame. I would like to build the 125cc motor, although I think it would be best to get a new cylinder. I will have to take a closer look at the forks later. I could even post a few more pictures of them. If anyone is selling a 125cc cylinder let me know! Thanks again everyone!
Posted: Wed Jan 03, 2018 10:46 am
by Stronger511
Bullfrog wrote:DOH! . . . and the "H" on the engine serial number makes it a 125.
Ed,
Thank you for the encouragement! I appreciate it! I do plan on building the 125cc motor for this project. I would also like to try and rebuild the other motor I have at some point down the road. Thank you again!
Posted: Wed Jan 03, 2018 10:49 am
by Stronger511
viclioce wrote:Let me know if you can’t find another Model 95 Cylinder for your bike. Also, Bruce Young, (Hodakaparts.com) May also be someone to check with. He may have a workable cylinder for you!
Victor,
Thank you for the information! I am having some trouble finding a cylider. Maybe I could check with Bruce Young to see if he has a workable cylinder. Thank you for your help!
-Mitchell
Posted: Wed Jan 03, 2018 4:37 pm
Check with Bruce first. If he has one, go for it! If he doesn’t, let me know.
Posted: Wed Jan 03, 2018 6:52 pm
by Stronger511
Victor,
I checked the website and he didn’t have one
Posted: Wed Jan 03, 2018 6:58 pm
by Stronger511
Tonight I started to work on the gas tank. I used some paint stripper and it worked quite well! I was glad to see the chrome underneath the red paint! The tank was scuffed up a little in order for the red paint to stick to it, so I may try to polish it or get it chromed again. I know there is still some paint left on the tank, I ran out of paint thinner
Posted: Thu Jan 04, 2018 4:06 am
by Bruce Young
Mitchell, My name is Bruce Young, my web site is Hodakapartsidaho.com please give me a phone call 1--208--571--2823. We can talk. I highly recommend as someone else did lets get a Manual, and parts book in your hands as quickly as possible, that should be your first step. You have received lots of great info and suggestions from several of the best Hodaka experts out there, I hope it does not cause confusion. I would like to ask you a few questions and suggest you step back and determine what you are going to use the bike for, show bike, everyday trail rider, race bike and etc, then start with frame and work thru what you have and go up from there. Many of these bikes have thru years been built up from misc pieces, by diff owners and etc. Its hard sometimes to determine exactly what one has when they pick up a few pieces and try to make something better depending on the new owners wants and needs and budget. Give me a call and lets get you off from the beginning. Bruce Young
Posted: Thu Jan 04, 2018 4:56 am
Bruce's offer to discuss your project is something you ought not miss out on. A primary planning goal is to know where you are going when you start your trip -- and to know what you've got in hand to help you get there.
Since your machine is an amalgam of various Hodie parts from Ace 100 (rubber covered foot pegs) to Combat Wombat frame, to Road Toad(?) rear hub, to Wombat air cleaner . . . and you aren't yet familiar with all things Hodaka . . . Bruce can really help you out.
But before you call Bruce, I'd recommend doing a bit of thinking about what you want to do with the machine after you get it running, cuz you'll do different things if your plan is to go road/trail riding vs. vintage motocross.
Posted: Thu Jan 04, 2018 5:23 am
Mitchell, there's some sage advice from some really great guys. Regarding your tank, two things. First, how cool the tank was preserved by leaving it full of fuel. That will all clean out leaving you a pristine tank. Secondly, from what I can see, that tank should polish out beautifully. A decent drill mounted buffing wheel and polishing compound set will run you about $20 at Harbor Freight and I'd bet that with a little time and elbow grease, you could get mighty close to a show chrome finish on that baby.
Posted: Thu Jan 04, 2018 5:38 am
by Bruce Young
Thanks Ed for your additional comments, the new or first time Hodaka Owners, are at a loss, when they pick "something" up to complete a dream to ride a vintage Hodaka. Thanks for your help, so many of the Machines picked up today, have lots of misc parts on them. We in the Hodaka world with a lot or little old school experience need to help them, and remember they just might want to join the Hodaka Club and goe further with their Hodaka experience. Thanks again all you guys for helping this newbie with so many great suggestions so quickly. Bruce
Posted: Thu Jan 04, 2018 4:12 pm
by Stronger511
Thank you again everyone for the great advice! Bruce, I will definitely be giving you a call soon. I appreciate you offering your help and expertise. I do need to first figure out what I plan on doing with the bike. I am leaning toward hopefully using it for vintage motocross and some occasional trail riding and desert trips. I recently bought a workshop manual for the Wombat and Combat Wombat from the Struckly Hodaka website, and I have a parts list as well. Both have been a huge help. Thank you again everyone for the great advice and encouragement!
-Mitchell
Posted: Fri Jan 05, 2018 5:49 am
Hey Mitchell, you were being so well taken care of by the Gang that I hadn't made contact. Welcome to the bunch. It looks like you have plenty of things to keep you busy in Hodakaland! Carry on!
Maxie AKA Max
Posted: Fri Jan 05, 2018 7:49 am
by squid on a 300
Danny Cooke had a completely rebuilt and refinished CW motor for sale a few months back...he had it posted on the Freinds of Hodaka Facebook page back in March you may want to check with him.
