Super rat date!!!!
Blackl79
Super rat date!!!!
Post by Blackl79 »
Where do you find the year make on a super rat? Thanks
Dunn111987
Re: Super rat date!!!!
Post by Dunn111987 »
Not sure of all the super rats, but on the chrome tank ones there should be a tag riveted to the front of the steering head of the frame. Has the year and month of production.
Blackl79
Post by Blackl79 »
Thanks,I will check.
Blackl79
Post by Blackl79 »
It's a chrome tank Rat,but no plate on the front.
Dunn111987
Hmm that could be a problem... maybe check the number stamped on the right front of the engine or frame number stamped on the left upper rear of the frame and compare it to the list on Strictly Hodaka. Might give an idea...
Post by Hydraulic Jack »
All the Rats had frame numbers stamped on the frame. The number should place you in the relative range of production date. The chart is on the Strictly Hodaka website. If you have trouble finding the chart, post your number, and someone will look it up. Look on the left side of the frame up high around the seat. Should be stamped in plain sight.
Blackl79
Post by Blackl79 »
Thanks for the help. Will check it out.
