Lots of leaking petcocks..
Posted: Fri Apr 17, 2015 5:49 am
by turbokh
I've got 3 Combat Wombats, so that means 6 (SIX!) leaking petcocks.
I've considered plumbing in some of those $4 plastic lawn mower shut offs on a few of the bikes.. how NOT cool would that look? :/
Is there a proven way to rebuild the original brass petcocks, or should I just spend the $240 and buy new ones?
Re: Lots of leaking petcocks..
Posted: Fri Apr 17, 2015 11:52 am
by MTRob
JB Weld works.
Posted: Fri Apr 17, 2015 1:24 pm
by SpokaneHodaka
Is the petcock not shutting off or is it leaking where it meets up to the tank? I would think that a little valve lapping compound used on the internals might help the surfaces mate up and stop leaks. I recently took mine apart and was able to use a little elbow grease and a medical rag, nice to have a wife that works in the OR, and they are doing great.
Posted: Fri Apr 17, 2015 4:25 pm
by Zyx
Description of the problem, and photos will help focus the advice.
Posted: Sun Apr 19, 2015 9:45 am
by turbokh
Sorry.
They leak when they are In the off position.
They don't shut off.
There is no leak where they screw into the tank(s).
Posted: Sun Apr 19, 2015 10:50 am
by SpokaneHodaka
It sounds like in your situation the valve lapping compound used in moderation should help the body and lever parts of the petcocks mate up.
Posted: Sun Apr 19, 2015 11:19 am
They do come apart, have you peeked inside? I had all those symptoms on my 94 and they were cured with disassembly and clean-up. Seems like the older brass ones were curable with lapping.
Max's small input--hopes this helps and give us a final report, It is a common problem.
