Lots of leaking petcocks..
turbokh
Post by turbokh »
I've got 3 Combat Wombats, so that means 6 (SIX!) leaking petcocks.
I've considered plumbing in some of those $4 plastic lawn mower shut offs on a few of the bikes.. how NOT cool would that look? :/
Is there a proven way to rebuild the original brass petcocks, or should I just spend the $240 and buy new ones?
MTRob
Re: Lots of leaking petcocks..
Post by MTRob »
JB Weld works.
SpokaneHodaka
Post by SpokaneHodaka »
Is the petcock not shutting off or is it leaking where it meets up to the tank? I would think that a little valve lapping compound used on the internals might help the surfaces mate up and stop leaks. I recently took mine apart and was able to use a little elbow grease and a medical rag, nice to have a wife that works in the OR, and they are doing great.
Dale Kassa
Spokane, WA
Zyx
Post by Zyx »
Description of the problem, and photos will help focus the advice.
turbokh
Post by turbokh »
Sorry.
They leak when they are In the off position.
They don't shut off.
There is no leak where they screw into the tank(s).
SpokaneHodaka
It sounds like in your situation the valve lapping compound used in moderation should help the body and lever parts of the petcocks mate up.
Dale Kassa
Spokane, WA
They do come apart, have you peeked inside? I had all those symptoms on my 94 and they were cured with disassembly and clean-up. Seems like the older brass ones were curable with lapping.
Max's small input--hopes this helps and give us a final report, It is a common problem.
