Rod repair
rtboone
Rod repair
Post by rtboone »
Is there any reliable way to repair a worn out wrist pin hole in a model 99 connecting rod? I suspect that a new rod kit is the only solution.
Tom
dirtsquirt80
Re: Rod repair
Post by dirtsquirt80 »
that's what I would do. the rod kits aren't that expensive. Scott
Re: Rod repair
If it's bad enough that the small end is worn out, pretty sure the big aint far behind. Better to renew it with a rod kit and be done with it. And while your at it, crank bearings are next on the list to do.
