Current limiter
Ed-de
Current limiter
Post by Ed-de »
Does any one know where to mount the current limiter on a wombat(94a) ?
Re: Current limiter
Ed-de,
I believe that the current limiter on the 94A was mounted to the battery box under the flasher. By the way, there is plenty written about voltage regulation on the Wombat's. The model 94 had no regulator. The 94a added the current limiter. The Road Toad's added an actual voltage regulator. It is advised to replace the 94a current limiter with a Road Toad voltage regulator (or equivalent).
You can perform a search of "voltage regulator" in the search box at the top of this page to locate a number of other posts on this subject.
rlkarren
Re: Current limiter
Post by rlkarren »
I'll second that!
Toss the current limiter and replace it with a Voltage Regulator unless you're trying to do a period correct resto. But, if you intend to ride it and use lights, rather than having a Trailer Princess, a voltage regulator will do a MUCH better job.
MTRob
Re: Current limiter
Post by MTRob »
I tried to send you a picture of where it goes. Right under the battery box on the right side I still have mine and works great
Email me and I'll show you where it goes. (Still keep them original)
MTROB
