Two Stroke Oil suggestions...
I know everyone probably has a favorite 2 Stroke oil. Just looking for a couple good suggestions as I have no experience...
Re: Two Stroke Oil suggestions...
I use Bel-Ray Si-7 Full Synthetic in my Model 03 Wombat with injector.
I use Bel-Ray MC-1 Racing Full Synthetic in my Super Combat.
Yamalube 2R here. 32:1. All my riding is easy street riding.
Red line , Most expensie though , better protection than castor which is superior to all other oils , BUT has NONE of the dirtiness of castor. Better thermal stability than the rest which means more hangs on the cylinder walls for doing what it should do , lubricate.
I agree with Rich (racerclam) as I used a pint of Red Line that he sent me along with a super dupper port job on my Super Combat and it ran great. It was a little rich for the Bad Rock trail ride but it never fouled the plug. I haven't ridden it that much since, but it ran the Bad Rock for the second time again this year and it is still running the same plug. It is just not available for me locally unless I buy a case at a time so I elected to use the Bel-Ray MC-1 in it. The Bel-Ray MC-1 has been around since the 1970s as I used to run it back then. Probably improved since then.
A good choice is Silkolene, either injector or premix - good stuff! Plus, they are a major sponsor of Hodaka Days, their reps not only donate a ton of valuable merchandise, but personally work all week, helping out. Give them a try.
Bob Whitman
Bob Whitman
Rich and Bill,
At what ratio are you using Red Line? My local shop carries it and I'm thinking of giving it a try.
--Russell
--Russell
I use 40:1. I bet Rich uses even less.
Thanks, Bill. You're probably right, I think Red Line recommends 50:1 or even higher.bchappy wrote:I use 40:1. I bet Rich uses even less.
I took racerclam Richs recommendation and began using Redline at 50 to 1 in all 3 of the highly modified 125 Super Combats we use for motocross. The pistons will have a film on them when you tear the engine down after a race, but it does not foul plugs. It does not burn off the way other oils do, so the only draw back I have found is with jetting experiments. You have to trust the sound and pull of the engine since the plug always looks the same. It does not change color as with other oils.
I use Redline in my bikes, also my trucks,ATV,Boat, sold on the stuff.
MTRob
MTRob
Thanks For the suggestions! What kind of Mix should I be using for a new top end?
I'm going to go see what kind of oil I can Find around here....
I run 50 to 1 and my bike runs 12,000 rpm and never had an issue , 40 to 1 is waay more than needed , also when breaking in with red line run it hard initially , as long as your piston clearance is right , you need to get the ring expanded against the cylinder with comgustion pressure for getting the ring to seat , since the film strength is so tough or break in will take longer than with other oils.
Thanks for all your help guys!!!
other than a weed eater I haven't used 2stroke oil in some time.
Now if I could just find a coil......
