I BBQ’d the pipe when I first bought/rebuilt this Wombat. I bought it in November of 2020 and finished it up in the Soring of 2021. So it hasn’t been that long ago. Not ridden much at all, either.
But now, I can only get the bike to start, idle & rev (gently) with the pipe removed. So, I pulled the pipe off, removed the spark arrester and threw the pipe on the fire pit last evening. I’ve cleaned off the flaked up paint, sanded, wire brushed and cleaned the pipe and put the first coat of new ceramic paint on the pipe. It did smoke for over 30 minutes last night while on the fire. Hoping this takes care of it. If it doesn’t, is there anything else I should check to get her to run properly with the pipe installed back on the bike?
She has a VM24 SH-83B carb, configured as a stock carb but I use a 140 main with the stock 25 pilot jet, here at 7,000 feet in elevation, along with a stock 4E1 needle, 3rd clip position, 2.5 slide, stock everything else. New, freshly oiled UNI air filter in the stock air box. Points are gapped at .012.
I’ll be done with the paint, reassembly & reinstalation tomorrow.
