Model 97 Oil Leak at Kick Starter
sunnyd1960
Post by sunnyd1960 »
Hello Gang,
What's the fix for oil leak at the kick starter. Can seal be accessed behind clutch cover?
Sunny
Re: Model 97 Oil Leak at Kick Starter
Unfortunately, no. There is an O-ring in the center case half which will need to be replaced - and you have to "split the cases" to change it out.
sunnyd1960
Thanks Ed
