Did someone ask about FUGI?
Al Harpster
Post by Al Harpster »
I think some of you guys might find this web page interesting.
http://www.indiandirtbikeparts.com/file ... Engine.pdf
Note the interest in the 12mm piston pin hand written notes.
For folks on a quest for pistons this sort of sheds interesting light on the "small 12mm pin".
The Hodaka and Fugi may have been built by different firms, but I suspect they were all drinking at the same bar.
loachridge
Re: Did someone ask about FUGI?
Post by loachridge »
WOW!
Al; Thank you so much for that link.
So, far it does look like the engine I am dealing with.
loachridge
Those pages were really helpful.
Used them to double check the condenser mount and wiring.
And forgot to put a pin in making the clutch lever useless. But one look at the assembly drawing and I knew I left that pin on the bench.
It's all together and I added 3 miles to it today.
So, Thank You for that.
Al Harpster
http://www.indiandirtbikeparts.com/indianlineup.html
I believe you will find a wiring diagram for your bike at this site if you are willing to dig for it.
This site has parts available.
They MIGHT have a piston kit for your engine.
