250 fork seals
250 fork seals
Does anyone happen to know what the size of the fork oil seal might be for a SL250? Have one that's leaking a bit so......
Britt Boyette
Clarke MFG
A mind is like a parachute, it only works when you open it. Frank Zappa
Clarke MFG
Re: 250 fork seals
Thanks Rich!
Britt Boyette
Clarke MFG
Clarke MFG
Re: 250 fork seals
Well, that's not the correct size, anyone need a pair of 34x46x8 fork seals? They are 34x46x10.5 if anyone needs to overhaul their SL250 forks.
Britt Boyette
Clarke MFG
Clarke MFG
Re: 250 fork seals
Just push the seals in 8mm.
Re: 250 fork seals
I already have the correct one's on their way so... I did consider that but I do have the time to replace them with the same size I removed otherwise I would have. Cool thing about a low mile bike is all the parts of the forks look like NOS, I like it!
Britt Boyette
Clarke MFG
Clarke MFG
