Has anyone done a port map on a 125cc
Just wondering how close my measurements are to any one eles
It's not often that I do a port map
Port mapping
Re: Port mapping
I don't have any port maps for you - but may be able to help a bit with the following information.
Exhaust port height (distance from top of exhaust port to top of cylinder/head gasket surface) for the 125cc Hodies is as follows:
Model 94 Wombat iron cylinder, piston port - 32mm
Model 03 Wombat alloy cylinder, reed valve - 30mm
Model 95 Combat Wombat alloy cylinder, piston port - 28mm
Model 97 Super Combat alloy cylinder, reed valve - 26mm
Hope that helps.
Hope that helps.
Re: Port mapping
looks like I got it
I am impressed on how well mapped out this cylinder is
Worked on all kinds of bikes and snowmobiles over the years but the fit and finnish on these engines is something I haven't seen for awhile
looks like I got it
Re: Port mapping
Exhaust port 3/4"×1 3/8"
2 1/4"from skirt to bottom of port
1 1/4"from top of port to top of cylinder
Re: Port mapping
Re: Port mapping
The 1.25" measurement converts to . . . 25.4mm/in X 1.25in = 31.75mm. Which means you have an iron Wombat cylinder (model 94) - nominal 32mm exhaust port height.
