Head gasket
Dunn111987
Re: Head gasket
Post by Dunn111987 »
Got everything back together this evening! Fires right up on the first kick. Think I may need to change couple carb settings now, but the smoke level is way down from before. Everything tightened and torqued down good. And studs are right side up. Cleaned everything and put on new base and head gaskets, studs, washers, and nuts.
