Rear brake hub crown nut bolt
Help! I can't find the bolt which fits the rear brake hub and bolts on the brake stay rod. It has a hole drilled in the threads for a cotter key and the key stops the crown nut from backing off the bolt. It has, apparently, a different size bolt head than the average 6mm bolt. But I don't find it listed on the parts fiche pages for the Model 99 Toad. Does anyone know the part number? Is it the same size on the other bikes rear hubs? Let me know! Thanks!
Re: Rear brake hub crown nut bolt
OK I found it. It was on Sheet R with the rear swing arm parts and not on Sheet Scwith the rear wheel parts! Whew!
It is part number 909150
Got it ordered already, but thanks!
