I bought a rather neglected bike, so the plan is to fully restore it.
So this is it:
Comes with another parts bike, and this bunch of goodies.
Beauty! I've got all those parts I think, in among the pile of bits and pieces.BrianZ wrote:Yep, that's the lighting kit for the Squirt (model 96). There was no battery. The headlight was powered strictly from the AC magneto. If I was going to guess, I would say the switch in the headlight was used to turn the headlight on or off since there is no ignition key on the Squirt.
Excellent. That explains things nicely.BrianZ wrote:The Squirt was a "parts bin engineering" bike. It used an Ace 100 engine with a Wombat transmission and a Wombat frame. The engine already has a lighting coil, and the output wires were just tied off and left unused. The lighting kit was standard parts bin stuff thrown together to give the Squirt a headlight so you could ride the trails at night. The Ace powered the headlight directly from the magneto (no battery) and this was carried over to the Squirt. In the Ace the battery was used to power the horn and tail light, and with the emergency switch it could be used to power the headlight.
Thanks, I've added them to the list.BrianZ wrote:Pretty much all the hardware is zinc plated. I think the top triple clamp bolts were chrome and maybe the handlebar clamp bolts. The air filter cage is yellow zinc. Hodaka changed to yellow zinc motor mount bolts at some point in time. I think it was around 1973 but I am not sure.
If you are planning on keeping the lights, get the headlight rim chromed. The screws that hold the rim in place are chrome as well.
