Main seals
JimmyG
Main seals
Post by JimmyG »
I,m not sure if my first post made it threw so I,m trying again, On a model 92 ace100, which way should the right main seal be facing, with the crank removed and the seal and bearing still installed the seal face is facing the crank side, is this correct?
Re: Main seals
Yes, clutch side seal is properly installed when the "smooth" side is facing the crank.
JimmyG
Re: Main seals
Post by JimmyG »
Thanx Ed, Its been years since I,ve been into one of these
