Exhaust gasket
Posted: Sat May 31, 2014 3:25 am
Just received my exhaust gasket from SH. Thanks Paul for the gasket. I was wondering if it matters about the correct mounting side. Does it matter which side the gasket mounts to the pipe and head? Both sides of the gasket look about the same. If anything, one side appears to be a little more slick and smooth than the other. Also, should I use a gasket sealer on both sides of the gasket when mounting the pipe or just one?
Thanks, Marty
Thanks, Marty
