Timing, electrical, or carb issue?
Posted: Mon Mar 31, 2014 6:55 pm
I think I've run into this problem before because it seems familiar.. but I am not sure... It was discovered tonight while on a night ride and wondered if anyone could help and save me some time diagnosing the problem:
Bike runs great in with the key in the "day" position, but as soon as I turn it to "night", things go south. The following symptoms only occur with the lights on, (key in "night" position):
At idle it struggles to keep running, and frequently dies. While on the road, it does the same thing but it also has no power and acts as if it's flooding out. It will also occasionally miss and backfire. When I give it 3/4 to full throttle, most times it will clear out and run good until I back off the throttle again. If i switch to DC using the emergency switch it immediately clears up through the entire throttle range, same thing when switching between day and night position while standing still or riding. The problem also seems to get worse as the engine warms.
It seems the problem is isolated to the AC circuit but I keep thinking I need to recheck my timing, but if the timing was off, wouldn't that affect engine operation in the "day" position also? any other ideas?
I've eliminated the Voltage regulator as the problem and the coils tested OK. I checked and rechecked all electrical connections, and it also has new points and condenser. New battery. Carb has standard jetting except the main is one size smaller, (#140), for 4000ft elevation.
