Ace 90 Front tire size
jakecb420
Post by jakecb420 »
hi all, I am looking for advice on what front tire size to go with on my ace 90. I think stock front is a 2.50-17 however mine has 3.50-17s on it front and rear. my fender wont fit with the 3.50 17 on it so i need a smaller tire but i feel a 2.50 17 is gonna be a bit small with the over sized 3.50 on the back. would a 3.00-17 be too big for adequate clearance on the front or would a 2.75 be a better choice? or is stock the biggest we can fit? the tires are shinko dual sport 244. thanks.
rlkarren
Re: Ace 90 Front tire size
Post by rlkarren »
The Ace 90 came with a 2.50 x 17" front and 2.75 x 17 Rear. A little too skinny for me, so I have a 2.75 x 17" on front and a 3.00 x 17" on the rear and I think it looks great. The rear tire is maybe a little big for the fender, albeit very slight, but the front tire fits great.
AceHoodrat
Post by AceHoodrat »
Jake,
Did you have any problems with rubbing toward the front of the bike with the oversized rear? I did, had a 3.00-17 on the rear but that may have had to do with a wonky 40 year old tire, it was rubbing on the chain guard. Also, did you use a bead lock on your rear tire? I keep tearing valve stems, but that again probably has more to do with a 40 year old tire than anything :lol:. I heard that not putting the outer nut on the stem helps with breaking during wheel spin, but I'm assuming a new tire would solve the whole problem.
