Super Combat Stator
Jerry Johnson
Super Combat Stator
Post by Jerry Johnson »
How can I find out what the original stators were supposed to read out in ohms. I have 3 originals that all read out to right around 275 ohms. Is that what it should be? The Super Combats are different than all other Hodaka's and I can't find much of any info about them.
Thanks,
Jerry Johnson
Re: Super Combat Stator
I don't know if it will help or not, but the 76-77 Honda CR125 had a very similar CDI (many people have used them on Hodakas). You might see if you can find the specs on those and see if it is close to your readings. Just a thought until someone who knows responds.
Jerry Johnson
I remember hearing something about that earlier. Thanks for the insight!
Jerry
