Hello,
I need to replace my Left Side Crankcase on my Rat. The p/n stamped on the engine is 921001-1 and 2 BUT the PN in the Book is 931001.
Are these the same parts? Why is the PN in the book different than what is on the case itself? Is this because of the Serial Number being different on the Right case?
Thanks,
Rat Crankcase
Re: Rat Crankcase
Hello, we have plenty of 1/2 cases, for Left and Right for ACE 100, if they are the same
let me know, so we can talk, Bruce Young Hodakaparts.com Idaho,
This is a tech question I do not have experience in. But we have lots. Bruce
Re: Rat Crankcase
Hi Bob - I just pulled a bonafide set of Rat cases off the shelf - both sides are stamped with 921001-02
As you know, the right case countershaft bushing is bored for a needle bearing - of course an Ace engine would suffice, but you'd have to use a brass bushing instead (and that wouldn't be right!). An Ace left case should mount up fine
Hope that helps
-Laurie
Hope that helps
-Laurie
- rdbrooks14
Re: Rat Crankcase
Laurie,
Thanks a bunch. Left is what I need - to recover from a violent chain toss that ripped of all the mounts for shifter cover. Right is good so this is a perfect deal. You have confirmed what I thought to be the case.
Thanks!
Thanks!
Bob in MD
39F
39F
