I've rebuilt my Road Toad and everything seems to be working good, expect for the rear brake. My rear brake isn't engaging enough to stop the wheel. The rear brake worked fine before disassembly, so I'm wondering if I reassembled something incorrectly. The front seems to operate fine, just not the rear. My concerns: Is it possible to mix the front and rear brake shoes?... maybe I have the front shoes in the rear brake and vice-versa? Can the brake cams be swapped?... or are the shoes and cam unique to each drum and there is no way to accidently assemble them to the wrong drum?
Currently the rear brake pedal never engages to a stop point. I could essentially push the brake pedal until if flips the cam and then I have to manually pull the cam lever back to it's proper location. I've tried adjusting the rear brake lever on the cam spline, but I never get enough engagement... the cam can flip clear over. This is why I'm asking if I could have accidently swapped internal rear and front parts.
I'm trying to avoid disassembling both brake drums, unless I know parts could have been swapped. If swapping components is not possible, I'll order new rear drum shoes and probably a new rear cam.
Thanks,
Kurt
Road Toad 02 Brake Question..
Re: Road Toad 02 Brake Question..
I think you need new rear brake shoes, sounds like they are too worn. ------ Clarence
I don't have a conical front hub to check, so I can't tell you if you can mix the parts. They do have different part numbers. If they were working fine before, I would say either parts were mixed up or something didn't go together right. I would take them apart and check fit as I re-assembled.
Pics???
