Priming Oil Pump Lines
OK Hodaka folk. What is the trick to priming the oil pump lines on an 03 Wombat?
I have all the lines connected, throttle cable for the pump is connected and actuating, and I have oil in the tank. However, I can not get oil to flow from the tank to the oil pump. Even the oil line from the tank to the pump is empty, though there is oil in the oil tank.
This is my first oil pump primer, so any thoughts on how to get this done will be appreciated, especially by tomorrow! Thanks! :ugeek: Victor
Re: Priming Oil Pump Lines
victor i followed the manual when i did my 03. the one thing i did was after putting the oil lines on i took them off on one end and used a syringe to fill them up with oil then put them back on.
Thanks! This is going to help a lot! I don’t have an 03 Manual!!! :ugeek: Victor
I found a 3 ml syringe which should work. Going out to try it now! Thanks again! :ugeek: Victor
figured i would post this here as it has to do with a oil pump. back to playing around with my 03 wombat and noticed there's air in the line before i screw anything up thought i would ask if this is a problem or just a thing. and hope you all that attended HODAKA DAYS had a great time and thanks for the pictures and comments....albert
One of the reasons there is a recommendation to fill the tank with pre-mix, is to assure lubrication by way of premix while bubbles work their way through the oil pump during some easy riding.
thank you for confirming i will keep an eye on it ....albert
