Throttle Bar
Posted: Wed Sep 01, 2021 4:28 pm
Question about the throttle bar in the VM20 carb. I’m including 2 photos. One is a new one from Terry’s website, & the other is one which appears to be worn in the middle.
It almost looks to me, when I zoom in on the pic, that a “waist” of sorts has been worn into the throttle bar.
Alan has already tried replacing the cable, the throttle assembly and replaced the carb with a second, configured identically. A slide, not on the cable and throttle bar, has no issues moving freely up & down in the carb.
Does it seem there’s enough wear in the center of this throttle bar to cause an uneven drop of the slide, causing it to hang? That seems to be the only conclusion I can draw.
So, what say you?
So, what say you?
