93 Super Rat leaking forks
Posted: Sat Jul 31, 2021 5:01 pm
Hi All
I have an unusual leak on my 93 Super Rat forks it is coming from the underside of the fork outer nut, the fork oil runs down the outer fork tube and appears to be dripping from the drain hole. However as stated the source of the leak is actually the underside of the fork outer nut? I know this nut has an o-ring that I presume seals against the sliding bush and I believe that this is not making a good enough seal? Both the o-rings were replaced when the forks were stripped down however the sliding bushings were not replaced as they seemed ok. But the diameter of the top of the bushings does not appear to give a lot of surface contact to the o-ring and I am wondering if these bushings are the correct ones for the standard 938700 30mm forks that were on the bike? Does this diameter vary on the different forks used across the model range or is it a standard size?
Help needed
Cheers Edo
Help needed
Cheers Edo
