Looking for Model 94/A crank case
Posted: Fri Apr 30, 2021 4:45 am
by Simonkav
Hey everyone,
Catastrophic engine failure here - both case halves are toast. Metal sheared and jammed between the crank and the case, cracked the cases. Damage was done quick
. On the hunt for cases to rebuild the motor with. I don't see them available on hodaka-parts. I have an email into Terry, will try calling next week. Message me if you have a lead on any!
1972 Model 94a Wombat 125
Cheers,
Simon
Re: Looking for Model 94/A crank case
Posted: Fri Apr 30, 2021 5:20 am
by Roddy boy
If u are in Canada I have a complete bottom end for you. Ran it last year and all is good to go but seals are old
Posted: Fri Apr 30, 2021 10:05 am
by thrownchain
Yep, where you is makes a difference.
Posted: Fri Apr 30, 2021 2:57 pm
by Simonkav
Sorry, should have mentioned that. I’m in SF Bay Area, California.
Thanks,
Simon
Posted: Fri Apr 30, 2021 3:01 pm
by Simonkav
I’ll also post photo of the cases. I’m assuming they cannot be repaired based on where the damage is. Welcome feedback....
Posted: Sat May 01, 2021 1:51 am
by thrownchain
Pic would be good. Almost everything can be repaired by competent people,
Posted: Sun May 02, 2021 12:25 pm
by Simonkav
Posted: Sun May 02, 2021 12:27 pm
by Simonkav
Posted: Sun May 02, 2021 1:49 pm
by thrownchain
Ouch, tis fixable with the right guy.
Posted: Sun May 02, 2021 2:13 pm
Simon. Where do you live? Maybe someone close by can help you.
Posted: Sun May 02, 2021 4:11 pm
by Simonkav
I’m in San Francisco.
Ouch is right
If anyone knows a great case repair guy, definitely not opposed to trying. I figured they were shot!
Thanks again everyone!
I did see a post from Rich (racerclam) about doing case work. Doesn’t appear to be active anymore?
Posted: Sun May 02, 2021 4:19 pm
Here’s Rich’s website! You can contact him through there!
https://richstayloredporting.com/index.html
Posted: Mon May 03, 2021 6:02 am
by olddogs
You should be able to find a right side case half pretty cheap. The left side case is often chain damaged an will be more to replace as clean undamaged ones are getting rare.
Posted: Mon May 03, 2021 6:11 am
by thrownchain
I’ll have a set shortly, right side near new but non numbered, left side with previous damage already repaired.
Posted: Mon May 03, 2021 1:53 pm
by Darrell
Hodaka-Parts has new 03 cases for sale.
Are they backwards compatible with 94 internals? I think there's a mod required (oil passage drilling) to run the 03 on premix however.
Posted: Mon May 03, 2021 6:03 pm
I am sure I would have a set of cases, if nobody else does I would not rebuild your cases unless they were to a 1936 henweigh. ------- Clarence
Posted: Tue May 04, 2021 1:16 am
by ossa95d
Hahaha good stuff Clarence... I'm not falling for it.
Posted: Tue May 04, 2021 2:13 am
by captonzap
Oh, come on, what's a henweigh?
Posted: Tue May 04, 2021 2:18 am
Just about 7&1/2 pounds before she lays the egg. ---------------- old joke Clarence
Posted: Tue May 04, 2021 10:38 am
by Simonkav
taber hodaka wrote: ↑Mon May 03, 2021 6:03 pm
Appreciate the input. How might I connect with you regarding said cases? Feel free to PM or email me through the board.
Cheers,
Simon
Posted: Tue May 04, 2021 10:41 am
by Simonkav
Roddy boy wrote: ↑Fri Apr 30, 2021 5:20 am
Just for my learning - why the Canada limitation? I’m not hip to the challenges - shipping to US outrageous or customs not cool with it or just a PITA you’d rather not deal with?
Posted: Tue May 04, 2021 11:55 am
I wouldn't toss the roached cases. Some a$$-kicking aluminum fabber with a serious sand-casting jones might like to put them back into circulation. They ain't makin' any more.
