Wombat Carb for Super Rat???
Can you configure a 24mm Wombat pull choke carb to work successfully on a Super Rat? If so, can someone tell me all the changes needed? I have a 24mm Super Rat Carb on my 94. But that’s easier to figure out. Thx! :ugeek: Victor
Re: Wombat Carb for Super Rat???
Looks like I’m able to ID the minor differences! Same needle jet, same jet needle. Change the slide from 2.5 to 2.0; change the pilot jet from 25 to 30; change the main jet from 140/160 to 220! Should work, right? :ugeek: Victor
Well, the Wombat carb is too short front to back to work with the air cleaner joint!
I’ll see how the JB Weld holds tomorrow. Hopefully I can use that second carb! :ugeek: Victor
