Measuring float height
Posted: Fri Apr 02, 2021 5:01 am
by MichiganBrian
Do I measure float height with gasket in or out?
Re: Measuring float height
Posted: Fri Apr 02, 2021 5:43 am
gasket out and measure both floats, and only bend the little tab that touches the float valve. ------- Clarence
Posted: Fri Apr 02, 2021 5:57 am
by MichiganBrian
Sounds good. Thanks
Posted: Sat Apr 03, 2021 3:54 pm
Measuring is one way. You can also invert the carb do the floats are on top & level the float arm to the edge of the bowl. :ugeek: Victor
