Road toad fender
Re: Road toad fender
Will fit Model 99 and 02 Road Toad, Painted red it would be correct and work on an 03 Wombat or 01 Dirt squirt. Polished to its natural stainless finish should fit a Model 94 Wombat, and with some length trimmed off could be used on a Model 95CW or 96DS but would not be correct. Hodakas can be a lot like a variety pack of parts. Many models can swap pieces.
I just remembered to use these painted fenders on the 94 95 96 frames you need the later seat base with the longer rear mounting tabs for a no fiddle fit or the fender touches the seat bottom. I cant remember if you can modify the front lower mounting holes to compensate for the lower seat? I used to know this stuff.
