4 3/4” wide, 36” end to end. Rear 2 holes are 4 1/2” up from tail end. The fender mount screw holes don’t seem to be in the correct place.
On my Rat fenders, the rear back plate mount holes are 2 1/2” from the back end and the front number plate/fender to frame mount holes are at 11 1/2” from the end. This has no fender mount holes nor the reinforcement under the bottom side. Victor
Which fender is this?
Re: Which fender is this?
When you say mount holes don't seem to be in the right place? What frame are you trying it on? If it only has one set of holes and it doesn't look like the end has been chopped off, it would been a CW or DS. The 93 rat would have 2 set of holes, where the frame mount and the other plate mount.
Well I was comparing it to my Rats. Checked my CW & it doesn’t match the CW rear fender. Holes are about 11.5-12” from the rear fender tip on the CW & the Rat. I can compare it to my Squirt. Never thought to look at that one.
But as shown in the photos, the holes are only 4.5” from the end of the fender. No other holes except the front mounting holes to go to the frame behind the motor. Victor
Ahhh! Indeed! It is a survivor Squirt rear fender!!! Here’s the beck end of my unrestored 1973 Dirt Squirt!
Thank you Kelly!!! Victor
