Big Step Forward
Big Step Forward
Scored some much needed parts for my slow build Rat project.....lots and lots of elbow grease lies ahead
Re: Big Step Forward
Are you going to re-paint the tank?
Bictor
I believe I might...sooooo many parts that need cleaning attention and paint.
Actually have two bikes I'm working on.
My time is consumed with running to the sand blaster (Heads and jugs) welded stops on the neck for
the Cereini forks today...many parts on order, bushing install at Greggs, all new cables and some perches needed....the list is mind boggling...lol
The 080 over new piston is a wee bit loose after just a light hone...might use the 030 piston coming on the spare cylinder i have rather than risk short term run on the 080 cylinder. Lucky enough to have purchased that spare M motoe for $75.00. Comes in real handy. the bore guy I found may even port that 030 cylinder for me.
