1975 road toad
Re: 1975 road toad
I do not know if any are available or if there are any plans to have them produced. You can check with Terry at Hodaka-Parts on that. Greg Watkins of California Hodaka might also be able to provide a solution. If you strike out, one option is to modify your existing inlet by cutting off the rubber and then marry a Kawasaki KZ200 rubber inlet to it. Yamabond in between the two.
You can use the search feature above and look for "KZ200" for several posts regarding the modification.
