Ace 100 exhaust
Posted: Thu Feb 11, 2021 2:22 pm
by mac
My Ace 100 has the first (I think) style exhaust like the one in the photo. Is the later flame thrower style a worthy enough upgrade to search and spend for one or was the power about the same ?
Re: Ace 100 exhaust
Posted: Thu Feb 11, 2021 3:07 pm
Put a screw in the shroud keep this one pristine, it looks so good-- get another and build a hotrod. I like the newer pipe. -----Clarence
Re: Ace 100 exhaust
Posted: Thu Feb 11, 2021 5:04 pm
by mac
The one in the photo isn’t mine but just one I found on the web. I wish mine was that clean and original !
Re: Ace 100 exhaust
Posted: Thu Feb 11, 2021 5:48 pm
The Flame Thrower pipe is a performance upgrade for sure.
Re: Ace 100 exhaust
Posted: Thu Feb 11, 2021 6:10 pm
I agree with Matt.
![👍](//twemoji.maxcdn.com/2/svg/1f44d.svg)
Re: Ace 100 exhaust
Posted: Fri Feb 12, 2021 4:35 am
by mac
Thanks for the replies ! I’m going to have to search for one after I get the more needed stuff.
Re: Ace 100 exhaust
Posted: Fri Feb 12, 2021 5:16 pm
Hopefully if the used parts department on HPI comes to fruition, there may be a source for the late style pipes. Otherwise, they come up from time to time on ebay. If you have or know someone with good welding skills, your options improve. Its best if the complete, iconic Krizmann Ace 100 Spark Arrestor is included.
Re: Ace 100 exhaust
Posted: Wed Feb 17, 2021 7:34 pm
I have a flamethrower pipe if your still looking for one
Re: Ace 100 exhaust
Posted: Thu Feb 18, 2021 4:54 pm
by fortunet1
I have a question about exhaust systems (the rookie here) My flat tracker (in my post) has the threaded
screw into head BIG nut with the splines for taping it around. The pipe just slips between the two loose pieces
and is essentially held in there by friction between the two AND the exhaust bracket on the frame.
The exhaust that came on the bike shown had the spline like nut "trapped" on that pipe and is broken in half, do I have to buy an entire pipe (spline nut included) to replace that system ? Can I use the loose spline nut I have on hand ? Any opinions on what exhaust to use....or buy ?
One more question (while you're here) ...how do you remove the rubber kick start return rubber without damage...or maybe it's too brittle to attempt that? And install new ? Grease it up and whack it with a rubber mallet ? OK, funny rookie right >?
Re: Ace 100 exhaust
Posted: Fri Feb 19, 2021 7:45 pm
The rubber kick stop is simply pried out. It’s friction fit. I typically use a wide, flat screw driver blade to start it. Then I just pull it out by hand. Old, hard ones, or damaged ones can be replaced with new softer ones, from Hodaka-Parts.com. Look at the lower left of the parr’s list for Rubber Parts. Then find the model you need. There are differing sizes.
Re: Ace 100 exhaust
Posted: Sat Feb 20, 2021 6:40 am
by Al Harpster
A picture or two of the exhaust nut area would be helpful. Can't quite understand all the information provided.
Re: Ace 100 exhaust
Posted: Tue Feb 23, 2021 5:40 am
by dirty_rat
The screw on adaptor is what was used on the original Super Rat pipes and many of the aftermarket expansion chambers. Some of the aftermarket expansion chambers (like Torque Engineering pipes) came with the captured exhaust nut, like what came on the Ace pipes. If your pipe will fit into the screw on exhaust flange, it should work fine. The slip fit exhaust usually also had one to two springs that go from the header pipe to the cylinder, to help hold the pipe in.
Re: Ace 100 exhaust
Posted: Fri Feb 26, 2021 2:52 pm
by fortunet1
dirty_rat wrote: ↑Tue Feb 23, 2021 5:40 am
Thanks, good info. Wish we could just add a thumbs up instead of a reply..
