C-clip size, used on the shift shafts two sizes
Sizes of the shift shaft c-clip that holds it all together, There are two sizes and wish to know what they are.
Re: C-clip size, used on the shift shafts two sizes
What the two sizes of c-clips used to hold things together, on the shift shaft. There are two sizes, need info for a future project. Thanks
Bruce, Here are some approximate numbers as they do vary slightly.
Part number 904620 5.5mm
Part number 984620 4.9mm
Thank you Dale, that is exactly what I needed. Bruce
