Kick start oil leak
Posted: Sat Jan 02, 2021 12:51 am
by thirdstone
I have a very small oil leak from the kick start seal in a Wombat case . Apart from splitting the case , removing the shaft and replacing the seal is there anything I can try to make it seal ?
Re: Kick start oil leak
Posted: Sat Jan 02, 2021 6:08 am
The seal is inside. It’s a rubber O ring. Plus the shaft slips thru it. Opening it up is the only way I know to change one. It’s probably torn. And the kick shaft must be removed to access the groove into which it sets. :ugeek: Victor
Posted: Sat Jan 02, 2021 7:09 am
You ask is there anything I can try? I could list a few but how much is it leaking, 1 drop per day, a teaspoon per hour? First there is little to no pressure in the transmission because it is vented, how about some automatic transmission stop leak, I don't know if it would work or if anyone has ever tried it. How about a seal slipped over the shaft, a kick shaft roller thrust washer and a spring with thrust washer, going against the spring cover? Then the option of buying 4 quarts of oil at a yard sale for $3.00? If it is going in the house or museum I would split the case and fix it. Just me ------- Clarence
Posted: Sat Jan 02, 2021 7:21 am
. . . and here is another thought for a "short cut" to ATTEMPT to reduce or stop oil leaking at the kick shaft O-ring. Try some "EZ Turn" (aircraft fuel valve lubricant). If I were going to try it, I'd "squegee" some into the gap around the shaft with my finger. It is a sticky/thick "grease" which is not soluble in fuel and might work to handle the motion and the near zero pressure leak sealing need. Aaaaannnnd, it might not work.
Posted: Mon Jan 04, 2021 6:55 pm
by thirdstone
Thanks guys, it’s about a drop an hour or longer. EZ turn isn’t something at the hardware shop . I’ll try blasting it with compressed air,maybe a bit of grit in the seal. I know it’s most likely an engine disassemble coming up.
Posted: Tue Jan 05, 2021 4:19 am
Baggy/2strings. -----------Clarence
Posted: Tue Jan 05, 2021 9:18 am
by thirdstone
taber hodaka wrote: Tue Jan 05, 2021 4:19 am Baggy/2strings. -----------Clarence
I have zero idea what that means
Posted: Tue Jan 05, 2021 2:18 pm
:lol: Are you describing the components of a DIY kick shaft diaper, Clarence?
Posted: Tue Jan 05, 2021 3:43 pm
matt glascock wrote: Tue Jan 05, 2021 2:18 pm :lol: Are you describing the components of a DIY kick shaft diaper, Clarence?
Gee Matt! That sounds like something no one wants to touch!!! LOL! :ugeek: Bictir
Posted: Tue Jan 05, 2021 4:37 pm
by thirdstone
Never thought I would be Trolled on the Hodaka forum but there you go .
Posted: Tue Jan 05, 2021 4:59 pm
What does that mean? I'm not computer savvy.
Posted: Wed Jan 06, 2021 3:59 am
For those of us that owned a 1936 Harley, we always had a catch pan or hubcap to catch the oil. Just letting the new world look back on yesterday a baggy and two strings to hold the baggy up, dry humor drought year. ---------Clarence
Posted: Wed Jan 06, 2021 6:13 am
by MTrat
Thanks for the clarification, Clarence. My 1930 HD had the total loss oiling and required the hubcap catch pan. Any effort to stop the Hodaka kickshaft leak without opening the cases would be my first effort.
Posted: Wed Jan 06, 2021 7:02 am
by Larry S
I agree with Clarence. Put a diaper (or baggy) under it and ignore it until time for an engine rebuild.
Larry S
Posted: Wed Jan 06, 2021 1:48 pm
hmmm, seems more like an ostomy bag than a diaper. ;) (no trolls here - just good natured ribbing :roll: )
